A girl needs help install options
robinredd said:
Hi and ill get right to the point .
I like my music load , and this is what i got , 4x JL audio 6x9 tr690 txi evolution's, 60 watt rms peak 225 watt 4ohm each
2x 6x9 infinity reference series 100 watt rms 300 watt peak 4ohm each
1x clarion srw 1283 600 watt maximum music power daul voice coil 4ohm is all i can find out (? rms)12" sub
optional but available 2x Rockford fosgate 10" Power handling(RMS) - 100 WattsPower handling(Peak) - 200 WattsImpedance - 8 OhmsSensitivity - 86 dbVas - 2.6Fs - 33Qts - .63Xmax - 5.08
i have 1x daul XPR540 Power Output: 150 Watts x 4 channels @ 4 ohms 300 Watts x 4 channels @ 2 ohms 600 Watts x 2 channels @ 4 ohms (bridged) Peak Music Power Output: 1200 Watts @ 4 ohms Signal to noise ratio: 75dBA (reference: 1 watt into 4 ohms) Frequency response: 20Hz ~ 20kHz
and 1x
Encore Series Amplifiers
TE-2300
Max. Power (Watt)
800
RMS @ 4-Ohm
150W x 2ch
RMS @ 2-Ohm
180W x 2ch
and my stereo is a Boss 508uab
 Max Output Power / Channel Qty 50 Watts x 4
 Output Power / Total 200 Watt
now please could somebody give me some options on different ways i could hook this up as it is now it is not hooked up right ,and everybody around me claims their car installation installer (joke) and they change it and it's still not right any help would be very appreciated. robin
360W x 1ch bridged at 4 ohms
i have an 04 grandprix i just use factory replacement rears (dual cone) don't need tweets behind u if u good speakers up front..  u can just amp front speakers and power rears off hu if u have after market hu with hp xover u are set if not i'd get one my $119 kenwood made huge difference
I found a Lanzar Max MXA 234 MOSFET at a garage sale.
  • Max Series 2-Channel Car Amplifier
  • RMS Power Rating (14.4V):
    4 ohms: 100 watts x 2 chan.
  • 2 ohms: 150 watts x 2 chan.
  • Bridged, 4 ohms: 2000 watts x 1 chan.
[*]RMS Power Rating (THD):
  • 4 ohms: 150 watts x 2 chan.
  • 2 ohms: 200 watts x 2 chan.
[*]Max power output: 1000 watts x 2 chan.
[*]Stiffly regulated PWM (Pulse Width Modulated) MOSFET power supply
[*]LED power (green) and protect (red) indicators
[*]Bass Boost/EQ details (0 or +18 dB bass boost)
[*]Input impedance: 10K Ohms
[*]2/1 channel operation
[*]Variable input level: 200mV-6V
[*]Variable high-pass filter (40-250 Hz, 24 dB/octave)
[*]Variable low-pass filter (40-250 Hz, 24 dB/octave)
[*]Phase Shift: 0-180°
would this be better for the sub? and if yes how should i hook the wires
That amp would provide less power to the sub than the Boss 4ch you have now.  The reason is that you have a dual 4 ohm sub and right now you're bridging the Boss 4channel with 4 ohms per channel bridged - which means you're getting the most power capable by the amplifier.   For the Lanzar you'd have to wire it at 4 ohm stereo meaning 150W per coil (rated) which is far less than it can do in 4 ohm bridged.
Best scenario is you find a monoblock sub amp that is 2 ohm mono capable (all of them will be) and use it for the sub.
You can add a fan or two to cool the Boss 4ch if you're concerned about heat.
robinredd
CarAudio.com Newbie
robinredd
keep_hope_alive
