A few problems with my system
Ok, more information after testing.
I am using a 50hz test tone. I have my volume at 20 which is what I would normaly listen to my music at. I turned off BBE.
When I touch the volt meter to the power from battery to the ground I get a reading of 31~ When I touch the volt meter to the + and - going to the sub I get a reading of 11~ That is with the gain all the way up for both of them.
My amp is supposed to produce 725watts at 2ohms which means I should be getting a reading of 38~ volts...
When I turn it up and down however, the bass from the speakers will raise or lower with it.
Thanks for your help!
if its a sub woofer level adjustment, it shouldnt adjust your other speakers, only the preout voltage going to the amp and it should be maxed out to give your amp the full voltage, also the sealed box is probly part of the problem,
also if you have a hpf on your HU set it to like 120-140hz whatever you got thats close to it, i kno i set mine to 135hz and my friends pioneer only goes to 125hz. that should help keep the lower freqs from playin on your other speakers
pntballindude
pntballindude
Temecula, CA
pntballindude
