A bunch of questions
hdj20
F*CK SONY
1. Would A fusion powerplant 1000.1 go good with a 12" Fi Q? If not, other suggestions please.
2. What type of screws do you use to screw a sub into a box?
3. How do you hook up a sub to a home theater receiver?
4. What type of wiring is needed for a 1000 watt amp?
Thanks!
1. There are alot more choices that would be better, How much money do you have to work with?
2.Any big wood screw would work fine
3. If you wanna hook an amp up, then hook a sub up you have to have a head unit and a car battery. Hook your red and yellow wires from you head unit to the psitive terminal on the battery. Then hook the black wire from your head unit to the negative terminal on your battery. Then just run your RCA's from your reciever to your amp. Then hook up the sub, and your ready to go. Oh yeah...hook the power and antenna to the positive on your battery from your amp, and your ground from your amp to the negative on batt
4. I suggest 4 guage for a 1000 watt amp
Thanks!
1. budget?
2. wood screws, for .75" wood, id use like 1.25" long screws or longer
3. i used a plate amp, built a box for the sub and mounted the amp onto it..hooked that up to the reciever. http://www.partsexpress.com/webpage.cfm?&Webpage_ID=3&CAT_ID=43&ObjectGroup_ID=505&SO=2&FTR=plate%20amp&CFID=1233995&CFTOKEN=50602932
4. you mean something like this? http://www.stingerelectronics.com/productDetails.aspx?delineate=578&CategoryID=19&ParentID=18
hdj20
F*CK SONY
hdj20
wisconsin
nauc
