99' Chevy Silverado mounting dimensions
Well, one thing you can do for the rear is build your own 4x6 plate. Buy a 4" component set and mount it and the tweeter in that spot or even just a 4" coaxial on a 4x6 plate. 6.5" will fit up front because I was running them for a while, the problem with Infinity Kappa may be the magnet depth but if I recall there is plenty of room back there, they may also make their speakers a bit bigger to about a 6.75" I was running them for a while though, before I switched to JL and then Focal.
Well I will probably be going with these for the rears:
http://www.cadencestore.com/ProductCart/pc/caraudio_detail.asp?idcategory=38&idproduct=113
They should be decent. Anyone ever messed with them?
stealth17
stealth17
Ohio
stealth17
