98 1500 Idle Issues and a few questions
  • 2
Terranova
CA
Whenever I turn my truck on and if I let it idle for too long it starts to sputter and make a really loud high pitched hissing noise coming from the engine. I have a gutted Catalytic Converter and I know my O2 sensors are bad but It sounds like an air intake problem to me but im not sure. I'll try to get a better video of it later so you can actually see and hear what it's doing. It happens without fail nearly every time I start the truck and let it idle for a few minutes. I noticed also that the engine starts to shake and wobble violently as if its miss firing possibly? I don't know what the deal is. My RPM's are speratic as well, they drop to 250-300 RPM at times and I give it gas and it takes it a few seconds to actually start climb in the RPM's, like its almost flooded..Any help would be great! Also, some input on a decent Catalytic Converter that is California legal but hopefully wont rob me of performance would be appreciated as well as O2 sensors. Im full of questions today :p heres a link to a youtube video I just posted up so you can hear what its doing.
http://www.youtube.com/watch?v=1RaQ-aZvn0Q
You have a vacuum leak, Start the truck and have a buddy keep it running then open the hood and look around the intake it should be easy to find.
According to Crutchfield, those JLs won;t fit in your dash, can't see why, just what it says on their site. it says those JL's won;t fit in the...
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
446
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
680
Well, there is always a bypass that can be McGuyvered. So next time you want to tackle that task, post it. We can help.
All you need. I've been running these for years in 3 different vehicles. https://www.amazon.com/dp/B01BL57JO2/?tag=caraudiocom-20
936
Terranova
Terranova
CA
ABSOLUTEAUDIO
    May 31, 2024
    May 24, 2024
