'96 Chevy 1500 Ext cab
ScottWatkins
Fuse Popper
I'm looking for some advise on speakers for my truck. It will be paired with the stock head unit. I'm not looking for the best, just something that sounds good for $150ish.
Also, are there any tutorials on how to remove stuff to get to the speakers?
Thanks for your help,
Scott.
there is an app you can buy from scosche that will help.but the doors are pretty easy. 2 screws in the door handle,1 in the where the lock switch is,unhook the rod holding the lock then pull the clip holding the window roll up handle or pop off the control panel for the windows and locks.just pull on the bottom of the door outwards,once the panel is loose then push up
ScottWatkins
Fuse Popper
ScottWatkins
Oxford, MS
trumpet
