93 Volvo 940 Sound System
Find a hole in the firewall in the engine compartment for starts or if there isn't one you may have to drill one then when you come into the car pop off the door sill panels and run wire under there right to trunk. Be sure not to pinch wire and always run your rca's on the oppisite side off car. Also I usually run the ground to a seat belt bolt. Make sure you sand to metal where your putting your ground.
84_Regal_LTD
84_Regal_LTD
Chicago, Illinois
Fordfool302
