That's a DD... Come on dude 13 mm xmax from a 6.5? IDK the price, I'm not a dealer!How about a 600 watt 6.5? 600 Series
Absolutely not. 60-200 is mostly mid bass. Sounds like you have a horrible designed enclosures or very weak front drivers.Rock music should be tuned between 60-200hz with strong subsonic filter. On my low tuned Sundown, rockmusic sounds ******, even Korn, which is mixed with rap, sounds ****, I have to switch the sub off.that's the problem of a very small enclosure. I'd bet on a bigger woofer but narrow, with very little excursion. and try to port the enclosure, only to hear how it sounds.
yes, you're right, I have a Sundown speaker, and it does **** at upper bass. but I barely listen to rock music so I'm fine. I love my sundown. It does exactly what I need. I had In the same enclosure a regular speaker, with only 110RMS and It had a muuch better sound for upper bass, but no way to get it lower than 60hz. now I can't get past 60hz hahahahahaAbsolutely not. 60-200 is mostly mid bass. Sounds like you have a horrible designed enclosures or very weak front drivers. Or let me guess, you have a mega roll surround? They do **** at upper bass. That's your fault for not reading up on it if that's the case.
A good low tuned box will play anything. It will excel at everything. But to do that some output has to be sacrificed. You can't have it all.
