8" low profile
the sundown sd2 8 will do good on that power and its relatively compact. we really need more info to give u good recommendations. mounting depth of ???? we know you have 300w at 2ohm of its a p3001. the memphis mlass 8 is ok too. but they have so many options we need more info mostly box info. how much space are you willing to give up and what kinda sound are you wanting? sq, sql, or straight spl. i even like the p28d4 for this setup if you are going to run a custom box tuned relatively low like 34hz
I'm actually putting this in a custom box that will fit in my jeep's center console. There will be minimal space, and I mean minimal. I just want to round out my sound with some bass.
If your last problem was the same as this one, you know exactly where to start. Does it change based on vehicle speed or engine speed? Does the...
124
620
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
763
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
horford
horford
kentucky
horford
Decebal
    Jun 10, 2024
