8-ohm speaker question
tigey
If I have 8-ohm speakers covering the midrange in a 3-way network - in which the low and high networks use 4-ohm speakers - can I expect to have phasing issues? If the answer is yes, can I avoid this problem if I were to parallel-wire another set of 8-ohm speakers to the first two 8-ohm speakers (to achieve a 4-ohm set up)? And if I do parallel-wire the 8-ohm speakers (to achieve a 4-ohm set up) will a bass blocker between the 8-ohm mids cut off bass at the frequency for which they were designed? (It seems that I read that crossover points on passive crossovers can be changed unintentionally - and undesirably - by a change in a speaker's impedance.) Last, would the crossover points of my hu's 3-way active system be affected by either (1) parallel-wiring 8-ohm speakers, or running 8-ohm speakers in a system where the low- and high ranges use 4-ohm speakers.
Last, if you see any other potential challenges or problems, thanks in advance for the advice.
Thanks for your patience with a beginner.
tigey
tigey
San Diego
Jepalan
