***8 OHM DRIVERS (great info)***
yay... the IDW's are just bought are 8ohm.... of course that means I need to run them both //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif (where am i going to find 400w @ ohm) ohh darn...
i learned exactly nothing from that.
and his logic is off.
Running an amp that could possibly produceing 1000W @ 1ohm (especially when trying to get loud) @ 8ohm to only yeild 125w is like having lance armstrong pedal a single speed tall geared bike up a hill. Not like not using all your money in bank accound. The power potential is there but you dont have the torque to acheive it.
Also, rating 4ohm driver rated at 2.83v with a 90dB efficency compared to an 8ohm driver with the same efficency at 2.83v is mroe like the 4ohm driver having a 87dB efficency since the true SPL rating is sapposed to be 1w/1m not 2.83v/1m
also, the drive wont get twice as loud, it will be 3dB louder with the same given power input which you just slashed in half because you are running your amp at a higher impeadance so sonic output will essentially be the same. all othe things equal.
all in all just get 8 8ohm drivers and call it a day //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
To a point, but he is more gearing his info to a 4 vs 8 ohm debate, he does mention 2ohm aswell.
There is no "true" rating, they are often rated using different units. Point is, by the very nature of an 8ohm coil, they have the capability to be more efficient, and they usually are.
He never said anything about getting twice as loud, they would, theoretically, be about the same loudness, but with using much less power with an 8ohm sub . And the power wouldnt be "slashed in half" Power compression would raise the impedance high enough on the lower compression driver so that a 4 vs 8 ohm nominal impedance subs would actually be much closer than that.
PS your spelling is terrible! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Forgot to add this:
Doubling power will NOT double your acoustical energy (or your "sonic output" //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif ). It takes 4x the power to do that, well, actually MORE than that due to compression and the like.
The article talks about drivers and people automatically assume subwoofers.
The driver sensitivity issue is more interesting if you look at tweeters and pure
midrange drivers.. for subwoofers it's a different can of worms to analyze because there is more going on.
I have some planar tweeters that are 13 ohm, 103dB sensitivity, mids are 8 ohm
100dB sensitivity, compression drivers with horn lense with even higher ratings.
None of these are typically used in car audio, many people don't even use it
in home audio, but the stuff exists. Point is, you can get loud with few watts with
high sensitivity drivers.
Slammed
Striking Accord
Slammed
Gotham City, NY
squeak9798
