8 Obsidian Audio 18's in an Astro
bigbud747
Well now that he has the subs, i figured i would post this up on here. I built the box a little over a month ago, but he just now got the subs from OA, so he's wiring everything up today and finally getting it playing. I'll post up all the pictures i have of the box build and what it looks like now. He wanted a low end ground pounder, and i gave him just that.
Box specs:
40 cubes NET
560 sq in of port
32 hz tuning FTW!
10 Powerware AGM batteries
300 amp alt
2 sets of Focal mids and highs (i have a feeling he's going to need more)
Don't think I've ever seen a setup in an astro that wasn't a wall. Should be interesting. I would have used threaded rod personally, though.
Wanted to keep cost down. Ran stress and strain analysis on this style of bracing and the numbers came out looking good, so i went with the truss style bracing. Some people might comment on a single baffle, but with t-nuts there won't ever be a problem.
Blake (owner) had talked to Hank about his box. We decided since blakes van had a little more room (length wise) and less room width wise, we would do 8 instead of 9.
Blake uploaded some good pictures he took with his Nikon. After he put everything in he said it was turning the van into jelly. The sliding side door looked like it was going to fall off. And the only amp he has in now is 1 AQ 2200! Can't wait until he gets 3 more 2200's and shows those subs some real power. Hopefully we'll get a video in the next day or 2.
A Link would be very helpful. Id be interested in taking a look at some gear
223
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
342
bigbud747
bigbud747
Stillwater, OK
jaeguerra909
Decebal
    Jun 10, 2024
