$7 Box Design
Kastlez_
PM ME FIRST WITH WHAT YOU HAVE IN MIND.
1. Car. Year, Make, Model:
2004, Honda Accord
2. Subs. Make, Model, Size, How many:
(1) 12" TC Sounds - Neo AXIS
3. Power. How much power per sub:
AQ2200d @ 1.5ohm
4. Goal. SPL or SQ:
SQL (Anything but straight SPL won't be competing)
5. Sealed or ported:
Ported
6. Sub/port placement:
Sub Back / Port Back (Open whatever works for tuning)
7. Max dimensions:
13.5-14 Height // 30 Width // 15-17 Depth
(Must fit flush mount on front baffle 11.16″ inner ring 12.60″ Outer diameter)
8. Desired NET vol and tuning(optional):
2.0 @ 33hz
9. Finish:
None
10. Zip code for shipping:
None
11) Additional comments:
Double baffle/flush mount: YES
45's in all inside corners: Possibly if beneficial
T/S parameters (not exact motor but very close)
Qts: 0.327
Qes: 0.343
Qms: 7.387
Fs: 29.1 Hz
Re: 4.57 (series)
Vas: 37 L
Mms: 290 g
Cms: 102 uM/N
BL: 26.63 TM
31" wide x 13.5" high x 16" deep
3 pieces 31" wide x 13.5" high (front and back piece, and one is for your double baffle flush mount)
2 pieces 31" wide x 14.5" deep( top and bottom piece)
2 pieces 12" high x 14.5" deep(left and right piece)
port is 12" high x 2.5" wide (inside dimensions) x 33" long
1 piece 12.75" deep x 12" high
1 piece 21" x 12" high
after sub and port displacment your looking at 2.0 cubes tuned to 33hz
exactly what I PMed you with
Not to be an *** but I was looking for a full design. Everything you gave me I could have simply typed into a calculator
I'm waiting for a certain designer if not Ill come back here
Wow, you are a Tool. There is no accurate online Calculator. You just wanted a free box design, and well I guess you got that. I design boxes through a program called AutoCad Inventor. I draw a 3D that actually has the port running through it to get exact inside space. Now I suppose I could have sent you the finalized design if that is what you was looking for (a 3D model) but first you have to purchase the several thousand dollar program to view it.
you say $7 right?
34x17x16
umad?
Haha.. whys everyone on my case. I can do the work but if i want pay someone who specializes in designs then I will do so.. The thread is getting ridiculous.
good day
Kastlez_
Kastlez_
Bay Area, CA
9515ROB
