6 speakers on mono amp
Can I run 4 6.5’s and 2 6x9’s in parallel on a taramps md1200.1? All speakers are 4 ohm, final ohm would be 1.5 ohm load so I’d need a 1 ohm stable mono amp right?
No. Four 4 Ohms speakers give a final 1 Ohm load. 6 gives a .66 Ohms final load. 6 coils divided by 4 Ohms. You could wire 3 in series for 12 Ohms then parallel them with the other 3 for a 6 Ohms final load. Amp is plenty powerful for that load.
Is there a reason you want to use that certain amp?
I’m currently running a ds800x4 on 4 6.5’s, i planned on adding 2 6x9’s to my saddlebags and thought i could run all 6 on 1 amp instead of 2.
You can run all six with that 4 channel. It is made to run at 2 Ohms per channel, which you are running it at 4 Ohms. You can parallel the 6.5s on the front channels and the 6x9s take the rear channels. Just make sure to adjust the front gain carefully.
SLAB153
SLAB153
Lafayette, LA
1aespinoza
vegang
vegang
