6 shiny new sub's ! but what make and model are they !?
sideshowbob
25
uk
http://i333.photobucket.com/albums/m389/machinedred/Mobile%20Uploads/IMG_20140118_183043.jpg
Hi guys I want to build a ported single box for all 6 sub's but I need to find the thiele for them any help greatly appreciated http://i333.photobucket.com/albums/m389/machinedred/Mobile%20Uploads/IMG_20140118_183150.jpghttp://i333.photobucket.com/albums/m389/machinedred/Mobile%20Uploads/IMG_20140118_183047.jpg its a 10 inch twin voice coil 4ohm each the dust cap seems to be stuck on by hand not perfectly centred like its a later mod to a manufactured driver , all i can find is a similar Orion basket and motor I need some specs as this box is going to take a lot of work .
sa-series.html
Looks like a Sundown SA basket, with some other motor. I am not sure though, we are gonna need a guru, or two.
Tons of subs have that basket. Subs before Sundown was even a company.
Could be anything. Orion used those baskets, Audiomobile used them, pretty sure Eclipse used them.
OP remove the rubber boot around the magnets on the motor. There may be a sticker on the motor with some identification.
Being that these are a mystery woofer and no one seems to know what they are or have any specs for them I think you are going to have to take a shot in the dark on this one or buy yourself a woofer tester or similar device. Most 10 inch subs work well in 1.25 cubic feet per sub tuned to 32-35 hz. With no tsp's I would start there and see what it sounds like. Looks like a nice little driver you have there. I am sure with a decent enclosure behind them you would be happy
Make an adjustable aeroport would be my 2 cents.
thanks guys ! Great suggestions , so far I have tried a 0.5,0.6,0.88,1 sealed and a 1.8 ported at 33 the driver really struggles under 0.88 , the ported 1.6 sounds amazing at 45 hz but tails off towards its port tuned frequency anything less than 33 is just massive movement with little dB . should I make my box for all six one big enclosure or 2 or 3 enclosures ? Its a tight squeeze in The back of my Austin mini pickup truck and the port will fire into the tiny cab (behind the seat) which is only a few cu ft itself , how will this effect my box size and porting ?? Thank you for your replies in advance .bob
250
397
513
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
826
530
sideshowbob
sideshowbob
uk
whitedragon551
    May 18, 2024
    May 16, 2024
