Sold 6" flared aero ports
k_schutte
I have three that I do not need. I DO need a 4" if someone has one laying around though!
They are schedule 40 PVC, 6" inner diameter, 8.5" at the the outside of the flare, 18" long TOTAL... I have them all three mounted on a baffle I sued for my BTL18 box but I will separate. Looking to get $30/ea for $80 for the baffle and all three ports. These are NOT painted or anything on the inside so they are VERY smooth. front pieces have four, countersunk screw holes for mounting.
In the first picture, that is the most recent and as you can see, I did not use enough tape and the right two separated. I'd say either use more tape than I did or use some rubber pieces from Home Depot type stores...
depends on the box size, a single 6" is 28.26" of port area. So, I would say it would be good for like 2.5ft^3 - 4.5ft^3 boxes...
I would assume for a pair of 12"s you are in the 3ft^3-4ft^3 range which would give you 9.42-7.06 sq.in. of port per cube which is just fine.
yea its 3.9 before all displacements
Does that account for the wood thickness too? If so, let's assume you will en up with like 3.5ft^3 net... that will give you 8.07"^2 port area per cube and being 18" long will get you around 32hz. You can always shorten it to get a higher tune as well.
So, simple answer. YES, one of these will work just fine for you.
k_schutte
k_schutte
cedar rapids, IA
k_schutte
