6 channel HU/ interconnects
Why would you "piggyback" a high amp from a sub amp fed from a sub output? Use the front and rear outputs from the HU for the mid/high amp. If you piggyback, you would lose the ability to use the HU subwoofer control and have to run full-range at the HU all the time to keep from cutting the high frequencies to the highs amp.
cause I'm a noobie dumb ***. I got 2 amps - an Eclipse 4200 and an dcs 4125. Next question: For 2 pair of 100rms/300peak components and 2 subs to be named later, what amp should I use? I got the eclipse before I knew.. Maybe I could find 2 10" subs @150rms and use the eclipse on dem?
darudeone
darudeone
Hawaii
darudeone
