How to convert AVCHD video
almader
What is AVCHD video?
It is a new HD camcorder format – AVCHD is compressed using the MPEG-4 AVC/H.264 standard, which greatly compresses the video without losing much in the way of quality. So if you want to convert your AVCHD video, then you need a program to help you, Aiseesoft AVCHD Video Converter is a powerful tools, which can convert other HD videos to AVCHD which owns high definition video quality and less spaces. This AVCHD Converter also assists you to convert AVCHD video to other formats for better editing or something else.
How to use this AVCHD Video Converter
Make preparation
Install and run Aiseesoft AVCHD Video Converter
Step 1: Click "Add File" button, it would pop up one window, and select the file you want to convert on this window.
Step 2: Choose output format
From the "Profile" drop down list you can find one format that meets your requirement.
Note: Click "Settings"button, you can set your own video and audio parameters, click "ok" after seted video and audio parameters.
Step 3: Click the "Start" button to start your conversion.
Just wait a moment, then your conversion will be finished.
Some powerful functions such as "Merge", "Trim", "Effect", "Snapshot", "Crop" are all available.
There are also Aiseesoft HD Video Converter, which is best HD Converter to convert HD video to general video, convert general video to HD video, or among HD videos.
Hurry up and try this powerful program! It will not let you down!
Free Youtube Converter
MTS Converter
AVCHD Converter is a top-rated and professional high-definition video program which provides you a good solution to convert hd videos(AVCHD (mts, m2ts), TS, H.264/AVC, MKV) from HD-Cameras to various common videos like avi, mpeg, dvd, divx, mov, wmv, mp4, etc. Extract audio from HD video, and convert among audios as well!
almader
almader
senen
susanjq
