6 Alts&AC on my tahoe inside ;)
its only like 13 feet lol
thank you lol
so is your mom,which is your dad lmao
lol you know thats all they do,and man im on a tight ass time limit, getting brand new psi subs built,rd amps are out,the sundown 4500s should be on there way today,might have all my batteries sold,if so gotta get all my 16v batteries in and my new xs power 12volters too..psshh its gonna be pushing it
got a long ways to go
Come on JP this is a fail to change everything 3 weeks before the biggest show of the year LOL
i know right,im sure it will never all work out lol oh and jizz on this
Figured yall might like this,i know i did
Also why do you have 7 power wires and then only 2 grounds? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Judging by the photos of the wire grounded to the chassis, I would say he is probably grounding the alts out to the frame. And is not done running negatives for rear batts?
Also to the OP, is there no shroud for that fan? Looks dangerous to even pop the hood with it running. If you are leaving it like that, that is.
holy giant battery buss bar!!!! that thing is tight!!!! and the install is clean!
thanks man
That looks crazy! You have to be the king of rebuilds.
or just king of having builds done and them never getting them finished all the way lol
its not done willis,its still in the progress,youll see
Judging by the photos of the wire grounded to the chassis, I would say he is probably grounding the alts out to the frame.Also to the OP, is there no shroud for that fan? Looks dangerous to even pop the hood with it running. If you are leaving it like that, that is.
its not done,fan shroud will be back on
I want to work at wherever you work at because they must pay well haha.
i just pump gas for a living..make minimum wage lol
dom sent me a text at like 1am last night that he put a 900amp load on it and the voltage didnt drop 1 bit,however the rpms did lol
Took a ride to some autoparts stores to have Prices alt tested. Some good vids of why NOT to have your alt tested by ANY of them. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Uhhh...which one is the positive?... The black one?.. OMG!!!
Almost as retarded as when Meade did it two years ago.
163
394
  • Locked
702
Amp
508
98HOEONSIXEZ
98HOEONSIXEZ
Greenville,Ms
Ali1
