6.5 subs
  • 6
It’s going under the back seat of a crew cab Sierra I just want to decide on the subs and then buy the amp that’s big enough to power them just wanting to put 2 subs nothing to crazy
You getting a prefab box or getting one built?
My opinion, if going 6.5’s in a crew cab, I would do 4. Four dual 2 ohm subs to be able to wire to a 1 ohm load. As far as power, you doing any electrical upgrades?
Will be going on a built box just need to purchase subs first also I really don’t want 4 subs I just want enough bass to where it will sound nice inside the cab I upgraded all my door speakers and tweeters to alpine type R will be running a Jl amp to push that but still need to buy one for the subs depending what I go for
Gotcha. If you could have the height clearance, I would do a pair of SSA f8L 8’s. Only need about 1.1 cubes net. But if you’re stuck on 6.5” subs, either the rds or dd subs will be fine.
2 DD 506 in 1 cube at 36hz worked well in my truck. Had 1-1500w on them at any given point
But I'd also suggest 4 unless you are gonna do some fancy box or the top end performers with decent power backing them up.
258
16
451
612
880
Mr4ces
Mr4ces
Tx
SlugButter
    May 22, 2024
    May 22, 2024
