On the contrary, I can't find any components that offer the flush swivel mount. I need it to swivel in a flush mount in a position low on my door. I need to aim them up because the soundstage is just too low. Already have a hole cut out.There are alot of component sets on the market that take only 60 to 80 watts per channel so you should be fine on that. As far as swivel mount is concerned I haven't seen too many pre made component sets that DON'T have swivel mount tweeters. I'm sure you'll see that your options are NOT going to be limited.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
What do you mean you can't find any?? Almost ALL tweeters come with a swivel flush mount cup.On the contrary, I can't find any components that offer the flush swivel mount. I need it to swivel in a flush mount in a position low on my door. I need to aim them up because the soundstage is just too low. Already have a hole cut out.
The Rainbow SLC's I bought don't come with a swivel mount. I am looking at the RE6.5 comp set. Also, the position is a little lower than chest height, not lower door. ThanksWhat do you mean you can't find any?? Almost ALL tweeters come with a swivel flush mount cup.
However, I would NEVER recommend mounting tweeters low in the door. No matter how much of a swivel mount you get it will only be able to point upward just so much. I would suggest finding a place on the door or the dash that is closer to chest level.
Never is a strong word to use. Frankly, down by the woofer is as good as up in the a-pillar, just different trade-offs. It's more of a personal choice in deciding which trade-offs you're willing to take. I run mine down by my woofers by choice. So does my brother. Both of us have used our tweeters up in the sailpane/a-pillar areas, myself with the addition of an active setup and time alignment. It's simply a matter of what trade-offs you prefer.I would NEVER recommend mounting tweeters low in the door.
honestly i would have to whole-heartedly disagree with you...i mean, the woofer to me is much less directional then a tweeter, and putting it down next to your foot firing right across to the other door sounds horrible. I mean, thats why we have imaging right?Never is a strong word to use. Frankly, down by the woofer is as good as up in the a-pillar, just different trade-offs. It's more of a personal choice in deciding which trade-offs you're willing to take. I run mine down by my woofers by choice. So does my brother. Both of us have used our tweeters up in the sailpane/a-pillar areas, myself with the addition of an active setup and time alignment. It's simply a matter of what trade-offs you prefer.
Absolutely. Not to mention the acoustic characteristics of the average square or rectangular room is a hell of a lot better than in a vehicle cabin, so speakers designed for the home will certainly perform much different than those designed for a vehicle. Setting proper imaging in a vehicle is usually a very frustrating, time consuming, and nightmare inducing journey, as those that have done so would most certainly agree with me.A pillars in the home eh? Im no guru but i would positioning woofers and tweeters almost completely depends on the surroundings and then how well the drivers perform on and off axis.
