6.5" components for $250-300 range
ghart999
380
Denver, CO
Gong into a 2016 Hyundai Sonata. Stock radio but going with Audio Control Para EQ and line booster. Amp is not decided on yet. But something around 4x50 @ 4ohm. i plan on running some cheap $100 coax in the rear doors unless you convince me otherwise to put the money in front comps.
Thanks
wew lad
wew lad inc
Mar 22, 2015
6,117
188
VA
Thanks
Better off putting all the money into running the front stage active with a 4ch amp that has a BPF option. Depends if you want loud or SQ. The silver flute and silk dome tweeter combo has been a long standing go to
Bobbytwonames
Professional Fisherman 🎣
Aug 28, 2018
1,800
-193
Quick question. Would it be better up front with a mid-bass/tweeter combo or a midrange/tweeter combo? I mean like a 6-1/2" midbass, not a big 8".
BCotrell
973
177
irvine, ca
Thanks
Your factory hu is going to to have factory eq. It will cause roll off on your mid/highs and sub. Check this out
then grab that ts400x4 taramps ($70) and run some silver flutes 6.5’s and ct2 tweeters. Skip rears. For Less than $150 for that speaker combination will be tough if not impossible to beat with any 250$ Passive comp set.
that’s like $350 in gear for great front stage not just a set of comps that won’t be optimized with factory hu
  • Like
Reactions: Bobbytwonames
Bobbytwonames
Aug 28, 2018
1,800
-193
I personally think midbass is better than midrange up front.
OP
G
ghart999
380
Denver, CO
Thank you. Can you explain the roll off a bit and how the Pioneer unit will help? If the problem starts at the HU, how would any downstream component help fix it. I was planning on the Audio Control DQ61. But having more control with a 31 band EQ that's controllable is nice. But how does the Pioneer work since it has an amp? I wouldn't be using it right? Just passing through onto the Taramps you suggested?
BCotrell
973
177
irvine, ca
So factory headunit has factory eq curves set to protect factory speakers. Wether you go aftermarket speakers or not, de-equalizing that factory eq with the pioneer unit will give you a full flat signal that you can then tune with 31 band range. The pioneer has an internal amp but it’s only 22 watts. It also has preouts for aftermarket amps. Pretty robust for 125$ the dq61 has signal summing so it sums the factory signals, it doesn’t enable a fuller signal. Yes I just said fuller.
OP
G
ghart999
380
Denver, CO
Sounds like the perfect piece at half the price of the dq61. People seem to like crossing the Silver Flutes between 60Hz - 2KHz. Then let the CT2 take over at 2KHz. And your confident in the Taramps 400x4 is not a POS for $68? Seems way too good to be true at this price and that it's class D and not A/B.
BCotrell
973
177
irvine, ca
Class d four channels have better efficiency. Most novices won’t hear the difference between an a/b although all the sq guys will prefer the a/b’s... don’t sweat that. If you have a few more bucks the pioneer gmd-8704 is a Budget gem at 120$ And has a small footprint too.
OP
G
ghart999
380
Denver, CO
Better efficiency means less amp draw? Do you really think Taramps MD-1200.1 and the 400x4 and still better than a decent 5-channel in the $350 price range?
BCotrell
973
177
irvine, ca
Better efficiency meaning less amperage draw from your electrical to get power. getting decent power out of a fifth channel can be expensive. Plus being able to get a one ohm load for your subs will be more juice and more efficient. The sundown 1100.5 for example is is half bridge(more draw on electrical system), $500+, and only puts out 800 watts to the rear channel
you’ll be pleased with an md1200. It’s rated at 12v too so if you’re electrical is solidified you’ll get great output
OP
G
ghart999
380
Denver, CO
OK OK. I will go this route. Will be getting the following:
Silver Flutes
MA CT-2s
Taramps Amps
DEC-S1000a DSP
Sundown SA12 v.2
Already found 36sf of Dynamat Extreme for $100 on Craigs.
Thank you for the help!!!
OP
G
ghart999
380
Denver, CO
4ohm because I didn't know I could find a 1ohm stable amp. Oh well. 600 watts will be plenty for my sub. Not an SPL car.
wew lad
wew lad inc
Mar 22, 2015
6,117
188
VA
No, not really unless you do a 3 way. It also depends on the tweeters. Mid-bass drivers tend to break up in the 1-3khz range
wew lad
wew lad inc
Mar 22, 2015
6,117
188
VA
Get a taramps ds800x4 or even 1200x4 if you want even more power but you won't be able to use all of it. Especially when it comes to the tweeters. I'd honestly recommend the ds800x4 just for the extra headroom. The pioneer amp and the taramps 400x4 are also great amps just less power and of course cheaper.
Honestly, you could bridge the ds1200x4 rear channels to the sub and run the fronts to the silverflutes and run the tweeters off the 22w rms EQ if you wanted to.
Just not familiar with that dsp, ideally you get 4 channels + 1 (or 2) channels that can be filtered. Not sure if you get 4ch of preout's + 4 channels of line level or not
OP
G
ghart999
380
Denver, CO
So the 1200x4... Can I run the fronts at 4ohm and then the subs at 2ohm? Is something like that possible? Also, do you think the DSP's 22 watts per channel would be enough for tweeters? I really like the idea of a single amp.
Create an account or login to comment
You must be a member in order to leave a comment
Create account
Create an account on our community. It's easy!
Log in
Already have an account? Log in here.
Users Who Are Viewing This Thread (Users: 0, Guests: 2)
Trending topics
