6 12's 4th order, 16v, 10k+, single cab s10 :)
treylittlefield
well i've got a good bit done so i figured i would start a build log, still have a ways to go but i got a lot of the things in i need.
build will consist of:
Single Cab s10
Alts: 2 Ohio Generator 300amp, 1 Mechman 250 amp
Headunit: Kenwood KDC-X994
Amps:US Amps for horns, Modded Zed Leviathan for mids, and 2 Sundown 3500d's for subs.
Subs:6 SA 12's
Frontstage: Illusion Audio CH-1 Carbon horns, Sundown neo pro 8's and 10's, Dayton 4 inch mids.
Wiring: 4/0 welding wire for 16v alts, all KNU flex for 12v side.
Batts: D3400 up front, 3 d1600s for 16v.
Im sure im leaving something out so bear with me. ive never done a build log nor a build to this magnitude.
BIG THANKS to Surreal, Toolmaker, and Jacob for helping me out. i know ive bugged the **** out of them with a million questions.
old setup:
New Stuff
Modded Levithian, does 150x6@8 and 250x6@4
Toolmaker is going to help me fix this mess
Box
Amp Rack
keep all the wire organized
Relay wired In with the needed Diode
---------- Post added at 01:29 AM ---------- Previous post was at 01:28 AM ----------
got a little more done today, next step is to resin the inside and outside.
Got a little bit done this evening...******* me resined the tops of the wood so i gotta sand it down so i can glue the sealed section together and it actually hold. tried sanding it by hand, that **** ain't happening lol
and here is what will be powering the subs
4 inch mids that will go in the dash
gotta hug them nuts
box resined. debating on painting the inside and outside. inside will be white with while leds more than likely. anyone got any suggestions on inside and outside? how many coats of resin will it take jsut to waterproof it? what prep work should i go to to get it ready to paint? noob questions i know, dont want super slick paint but i want it to look good.
1 of 2 braces added. other will run perpendicular to this one.
thanks toolmaker!! negative terminal is sideways a little to keep it away from the fender a little.
not much of an update, but got the sealed section done. also got the t nuts on the baffle. gotta wait on the gasket for the top. gonna sand the inside down good and paint it this week if i can get a warmer day.
amp situation will change more than likely. gonna ditch the US amps. jsut isnt practical and i have all the power with the leviathan. plan on building another amp rack since the current one is butchered up with a bunch of holes. it will help with tuning and make things all around better.
Good looking build, keep up the good work...I'm curious though, what type of mod did you have done to your Leviathan and who did the work to get those type of power numbers out of it at those impeds????
thanks
I'm in... looks good so far bro
thanks man
send it to stephen himself. he wont give any information on the mod nor tell anyone how to do it. lol
Man that's beautiful! Wish I had the ability to do something like that....
only my 1st real box....lol have done a few quick boxes. nothing like this though. lol
Hahaha, sounds like him....I'm looking at getting three, so I might need to give him a call bout some mods...//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif:naughty://content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
Any direction you orient a sub can affect it's output, this true even more so in a car. Nevertheless it doesn't add an order and generally...
treylittlefield
treylittlefield
Sand Rock, AL
treylittlefield
