6 12's 4th order, 16v, 10k+, single cab s10 :)
anyone have an idea for a battery/ amp rack. dimensions are 38 wide, 17 tall, and 10.5 deep. want it to be sturdy and will be mounted to the bed floor. i have access to 2x4, 3/4 birch and threaded rod. so possibilities are endless. lol was gonna mount amps on top of batteries with birch in between. any suggestions?
Since you're gonna cut the bed for the port anyway,why not blow a hole in the bottom of the bed and sink the batteries/amps in a box under the bed.It would be hidden behind the bumper,blast some Herculiner on it for water proofing and save that bed space for the stroller?
haha yeah i could do that...but im not. i have an idea of what im gonna do //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
got a little bit done today. decided to go ahead and seal up the box since im done with it. i put the leds in it also. worked on the amp rack for the front and back. the front is almost done and im still contemplating how im gonna do the back rack.
Here is the rack that i had built. i like the fact its pretty much done, but i dont like hat the bottom amp kinda closed in. i have to fans i could place on each end of it to help it out a little. would just mean more wire to run.
space that the amp has. roughly 3 1/2in.
here is the one i was thinking about doing after playing with the idea, i dont know if both amps will fit like that though and dont know if the batterys are gonna be to wide for the angle i would have to put the amps on.
this is a picture of the seal compressed on the ported chamber. i used this on my last 4th order and it did wonders //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
the new frontstage amprack. i like this a lot better. a lot more simple and will be easier to wire up in the end.
Clearance from the top of the amp to the next shelf
the start of the mess lol
all techflex and ziptied up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
one of the brackets for the horns under the dash
got the carpet back in and all the wires pulled through
Got the Boot put in and some SDS tiles on the back wall and foamed a little
Ran into a problem with the amp rack, with the wires under the carpet it made it sit up a little higher. so im going to have to make the back a little taller or something to fix it lol
here's a picture of the truck in case anyone was wondering...lol
this tool makes life a lot easier...lol
meet this guy. caught my knee a few times and literally was at the point of cutting them off. lol **** hurt
horns mounted
mids mounted
the wire ran from the battery to the distros
powa //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i absolutly HATE this thing. couldnt hook it up because it wouldnt work. ive sent it in 2 times already for the bluetooth being screwed up. ran the system without it and will probably leave it out. the horns sounded better with it, but right now its just not worth the headache.
got the amp rack 99% done. just gotta paint the front a little more where i missed some spots
started working on the doors since i couldnt get noone else to do em...lol its gonna be a TIGHT squeeze to say the least.
here is where i flushmounted with the grilles on, id say for the first time i did pretty good.
got this crimper off of ebay
contemplating if i wanna put this center console in or not. picked it and the door panels up at a s10 junkyard for $65. also picked up a set of neo pro 10s for $90 BNIB
treylittlefield
treylittlefield
Sand Rock, AL
treylittlefield
