5800watts rms electrical needed
darren700
got bu/\/\p?
OK, on my car presently i have 2 runs of 1 ga positive, and 2 runs of 1ga negative from the front to the back, i will be purchasing 2 kinetik hc2400's, and i have a delphi 180a ho alt. i plan to run either 2 2500.1's or a hifonics goliath, along side 2 elemental designs nine.2's bridged, for a total of 5800watts rms. is two runs of possitive and two runs of negative from the front stock battery enough to supply this kind of power? is there any other electronics upgrades you would suggest? thanks,
ps. this is for daily too
im using 3 kinetik hc2400s and an hc 1800 as well as a 225 amp alt for my single goliath. i am getting a bracket made as well to get a second 225 amp alt.
They love teh currentz
ill still go overkill and ground front batt to frame, and back batts to frame aswell, then alt ground to same grounding point as front batt
dont alty's ground to the engine chasis they're atttached to? would it reall ymake a differance if you already have the big 3 done?
darren700
got bu/\/\p?
darren700
Windsor, Ontario, Canada
mandos
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
