58 Farad Super Capacitor for $80 !!
Here's an idea.Buy a decent amp with all the capacitance it needs -- WHERE it NEEDS it -- built INTO the power supply.
Problem solved.
problem not solved, you missed the entire purpose of the capacitor, perhaps you should start at beginning and read through to completely understand the concept of stabilizing the line voltage..
i've always believed in caps and these ultra-capacitors are way cool. I was wondering if there was a way to wire in a cap in line with your battery for all the car's electrical needs so you will have strong start ups and every accessory will have strong stabile power. So now with these ultra caps there is no need for a battery at all? They have enough capacitance to retain charge and function as a normal battery?
The tweeter has to be crossed over somehow. Doesn't matter if it occurs at the HU, the amp or passively.
915
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
gstokes
FÜKENGRUVEN
gstokes
Beaverton, Oregon
ladysmanfelpz
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
