500w and lights dimming!
microhaxo
MINNESOTA
here is the info...
130 amp alternator
8 gauge wire setup
75A max load amp with a fuse rating: 40A x 2
500w rms powering 1 subwoofer
Lights are dimming quite a bit, what is going on?
before you shout the big 3, remember that 500w rms and 130a alt should power this with no problems at all..
so with all that being said what do you think is going on? my ground wire for the amp is connected to a bolt of the chassis in my trunk.
well im kinda doin wrong on the power wire, im using 8 gauge and i believe that is rated at 60 amp. but my amp draws 75w max and it has 2 40w fuses. Do you think the 8 awg could be the problem for the dimming?
car is 95 Ford taurus
amp is SONY XM 2200 GT
Maybe go bigger than 8 guage wire??? And yes, do the big 3; my car was done with 8 guage factory I upgraded to 2/0 and it is a world of difference.
Hmm, well i got this 8 gauge free with an old 10" sub i bought a few years back. Id be suprised if it wasnt rated true 8 gauge..
I think ill go and buy 4 awg and see if it makes a diff. Ill for sure do the big 3 if i dont see much of an improvement.
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Came across these. Rechargable, so you don't need to wire anything in and have a OEM look. I don't know if they're reliable or anything, I just...
Turns out that the big 3 cables connected the ground had some rust on the surface, brushed them with a wire brush and now there is no dimming...
Big 3 will not help dimming. Big 3 helps get more power to your amp, which is the opposite of what you want to reduce dimming. Either add lifepo4...
663
microhaxo
microhaxo
MINNESOTA
Rashaddd
maylar
    Jun 2, 2024
    Jun 1, 2024
