$500 to spend tweeter , 6 1/2 combo
  • 4
Jimg
CarAudio.com Regular
216
13
would like to keep the budget on the tweeters and 6 1/2 to less than $500 for the 4 speakers
will be running a true 4x100 watt amplifier. possible a 4x125 watt amplifier.
I will be running active on the setup. they JVC z1000 has plenty of settings to run a 2 way setup.
Toyota Tundra Crewmax
tweeters will be in the Sail Panel. or might put them in place of the dash tweeter location in the dash. Just depends on what works the best.
6 1/2 in the lower part of the doors.
you got $500 to spend.
what brand and model tweeter would you use?
what brand and model 6 1/2 would you use?
Subwoofers behind the rear seat will probable be Two 8 inch subs.
I would wait until I had the money to build proper pods/enclosures for them.
Even if if it was just out of MDF cuz we all know what fiberglass bills look like.
I warn you though, you will never be able to go back to just having them screwed into the door
I'm taking them off the midrange pods as they aren't needed. I have a set for the tweeters that are much more important but not installed in the...
20
331
Tons of options in that budget, including the cost of installation,
10
619
It'll look like a "Hawaiian professional" did your install then 🤣
17
No problem. I think alot of the issues I see on here are people aren't differentiating between AC (music) and DC voltage.
15
Jimg
Jimg
20 hz bass machine
    Apr 28, 2024
    Apr 28, 2024
