$500 Budget
firearm
I have a 2006 Ford F150 Super Crew in which I will be replacing the entire audio system. The one thing that I have settled on comps in the front door (BA Pro 50'S). I am undecided as of right now on using rear fill but would like to hear opinions on a good quality amp in the $500.00 range. The main feature that it must have is adjustability from either end of the amp as it will reside under the front passenger seat and I don't want to have to remove the seat to tweak the amp.
Please share your ideas
firearm
Off the top of my head I can tell you that the Ultimate line from DLS has has all controlls (exept for remote bass plug) on the longest side. They are beautiful amps too. Considering that the Pro's like some power, I would suggest the A4 brigged would give you around 250 x 2 @ 4 or so. The A3 is the dual mono which will do 150 x 2 @ 4, but is also more expensive....probably around your $500 mark.
MB Quart amps seem to be popular these days. Both the Q and Reference lines offer top mounted controls as well as a ton of features, flexibility, and POWER!!
Honestly, the search feature is your friend //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Good luck!
firearm
firearm
Lafayette, LA
FoxPro5
