500-700w @ 2ohm
ctmike
Looking for amp that'll go with my w6, and not looking to spend a lot. Had another thread for this but not seeing it, so post what you have for sale. Not looking for garbage brands neither, but decent amps that'll do rated+. Would love to find a pg xenon 600 or sundown sae 1000d
I have an Xtant a6001 ...told it has balls @ 2ohm..unfortunately I have 2 subs that neither do 2ohm. $125 shipped. got it from my electronic engineer buddy
Specs:Frequency Response: 20 Hz to 120 Hz +/– 1 dB
Number of Channels: 1
Watts per Channel @ 4Ω: 1 x 300
Watts per Channel @ 2Ω: 1 x 600
Recommended Load: ≥2Ω
Distortion (THD): ≤2%
Measured: 20 Hz to 120 Hz at rated power, all channels driven 4Ω
Signal to Noise Ratio: ≥ 100 dB
Measured: A-weighted in 20 kHz noise bandwidth @ 1 volt sensitivity
Damping Factor: ≥ 100 @ 100 Hz with 4Ω load
Input Sensitivity: 100 mV to 8.5 V RMS Unbalanced
200 mV to 17 V RMS Balanced
Input to Line Output Gain: 0 dB
On-Board Crossover: 24 dB/Octave Low Pass
Balanced Line: On Board
Power Supply: Fully Regulated, PWM
Operational Voltage: 10 to 16 Volts
Fusing Requirement: 40 Amp
Size (L xW x H): 11-5/8” x 9-1/4” x 1-7/8”
295mm x 235mm x 47mm
Subsonic Filter: 24 dB/Octave 20-80 Hz
Bass Boost: 0-12 dB @ 45 Hz
ctmike
ctmike
ct.
gentlejax
vegang
vegang
