5 single 4 ohm vc wiring options?
Well four in each door is 1ohm already, so 5 would drop it just below. If the amp runs 1 ohm fine, it should be okay running slightly below.
Idk if I trust it tho havent heard much about the 200.4s plus its an older amp which is sorta rare I dont wanna damage it but yeah the 4 will get a 1 ohm load but then id have to bride that and thats .5 ohm forget that lol
Oh you intend to run each side on 2 channels bridged? Then add two woofers to each door if possible, giving you six 4 ohm woofers per side. Wire in pairs in series - 8 ohms x 3 = 2.66 ohms a side. Bridged that's 1.33 ohm a channel.
Run 4 on 1 ohm, and then take the extra (#5) from each door and run those on one channel or something. I don't know how much you care about balance and fader, but I personally hate when a song purposely puts a certain sound or voice in one side. Makes me think something is wrong.
You can always adjust the gains to balance everything initially, and leave the balance and fader on the unit alone. Just my suggestion.
Edit: notice you have 4 in each door now? Leave it like that. If that amp is 1ohm x4 stable, then perfect.
He never said "sub" he just said woofer. I assume he meant adding another mid..but I don't see why..
Yeah it just seemed odd that he said mids first then woofers, sounded like he was planning on adding speakers of different sizes...Generally people don't refer to speakers as woofers unless they're talking about low end spectrum (i.e. not mids)
jaeguerra909
jaeguerra909
ontario,california
bubbagumper6
