5 ohm speakers???
95Prober
Hey guys,
I have a 3-way set of CDT's (6.5" woofer, midrange and tweet on each side)
and I connected the DMM just for fun on each side near my amp and both left and right sides read around 5 ohms. Is this normal for a 3-way set? Just curious
searched but couldnt find the specs. However, my concern is my amp. Its a 4- channel and I have the componants wired on the "front" setting of the amp. But is it ok to put 5 ohm componants on a 4 channel amp? The specs of the amp show just power for 4 ohm and 2 ohm speakers
lol, yeah of course it's ok. it'll just put out a bit less power then it would at 4 ohms. You could run 13 ohm speakers on your amp and it wouldn't be a problem. Just less power output //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
You are attempting to use 3 way components and don't know something simple like the difference between a 5 ohm load and a 4 ohm load? Just saying, not trying to be a dick, try to read about ohms and figure out what they mean in car audio. Basically what it means is that the resistance of your speakers is higher, so the will see slightly less power than the 4 ohm rating on your amp. It's very simple once you figure it out.
95Prober
95Prober
Canada
Buck
Mike Mccabe
