5 channel Class A, Class AB, Class D amp?
LeadSlinger
I read about one of these the other day; it's a 5ch amp with class A for highs, class AB for mids, and a class D for the sub. Problem is I don't remember who makes it and my search history got deleted. Lame.
Anyone out there know who makes one? Thanks!
I have never heard one. It must be one of the "boutique" amplifier brands, if such thing exists. The only ones I have heard of are straight class A/B, or straight class D, or a Class A/B on highs and class D on sub channel.
Wait, I found it! Audison Voce AV5.1k. At 4Ohms, 75Wx2 (class A) + 140x2 (class AB) + 600W (class D).
Audison Voce - AV 5.1k
I don't know my solid state amps as well as I know tubes, but with tube amps class A (push only) is not as accurate of a sound as class AB (push-pull). But guitar players aren't always looking for an accurate sound (why low wattage amps are so in demand - you can push them in to overdrive at lower volume), maybe it means something different in the solid state world? Anyone know?
it's got good cleans on the A & A/B side
The only vacuum tube Class A configuration I've used was transformer coupled.
Solid state is different, they run a psuedo complimentary/symmetry topology that's transformerless. You can bias Class A into the most linear region of the output device's characteristic curves. With the output devices conducting for the full 360 degrees of signal, you get lower harmonic and intermodulation distortion, better transient response, and less phase shift than A/B.
The question is are those advantages worth the extra heat.
I have the Audison LRx5.1k, which is the older version. I just want to say that the "A" channels are not class A, but class A "biased". I can't remember were I read that, on their site somewhere but I fail to find it again. The power ratings I see are a bit different too. Whereas the LRx is 50 x 2 Class A biased (4 ohms), 160 x 2 Class AB (4 ohms), 1150 x 1 Class D (2 ohms), vs the Voce 75 x 2 Class A(4ohms), 140 x 2 Class AB (4 ohms), 100 x 1 Class D (2 ohms). All in all, I prefer the power the LRx has over the Voce, but like the Voce's features more.
I think your numbers on the voice 5.1k is wrong
LeadSlinger
LeadSlinger
Saint Paul
smgreen20
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
