4th order port question
oldschoolboomer
building a 4th order for 8 concept css-10's. using the carstereo.com 4th order calculator, I know the ported section needs to be 3.24 cubes tuned to 58hz. it doesn't do port calculations, so i am using re's calculator for that. my question is about the port area. whats the rule of thumb? is it @1/3 of cone area?
no
use the biggest port u can possibly fit in ur ride
i hope that 3.24 is for 2 subs
80
Definately needs to be bigger. Go with around .6-.7 sealed per sub and then 1.2ish ported per sub, with around 20-24in^ of port per cubic foot of ported airspace. Tune to around 45-50ish hz.
gln305 says these subs get sloppy in more than .5 sealed. concept recommends only 1 cube ported, so I would assume these sizes would be too big. Or am I missing something? Here are the ts parameters:
Fs = 26.1 Hz
Qms = 4.34
Vas = 1.678 cu.ft
Xmax = 0.472 in
Qes = 0.377
Re = 3.2 ohms
Z = 4 ohms
Pe = 250 watts
Qts = 0.347
1-W SPL = 85.38
when I use an f3 of 36Hz, I get the following numbers for one sub:
sealed 0.445
ported 0.396
tune to 56.98
boost 2.36 dB
passband 36-90.2Hz
Qbp 0.76
when I try lower f3's it tells me my boost is negative 1.xxx dB.
Try a different calculator? Please enlighten...
I built one around 12 years ago for 2 jbl gtx 15's. I just guessed on everything. @ 4 cubes sealed into @10-12 cubes ported in a blowthrough. The port was the blowthrough. @ 6" x 22" 6" deep. Didn't know the tuning I just made the port as big as I could. The bass flexed my windshield, shook the doors and steering wheel to the point the striker plate was starting to rip. Windows of stores would flex when I got within 15 feet. All on 500 watts. Only problem was it would only play between @10 and 35 hz. I want the volume and efficiency in a more usable range. The goal is tons of 40-45 hz. Can you help me out?
oldschoolboomer
oldschoolboomer
white house, TN
galacticmonkey
