4th order friendly 10" sub
Jroo
Looking to do a 4th order porting through the ski hole in my Volvo S80. Had good results back in the day with a similar set up using old round Kicker solobaric. Again, will certainly go the 4th order route with some of the port externally into the back seat/ski hole.
Need a single 10 inch that can present a 4 ohm mono load to amp (Older Rockford 800a2)
Works well in 4th order
Decent sound, not looking to be the loudest or meter or anything like that.
Can go to $300 but would like to stay around $250 if possible.
I have been told the DD 2500 series, but they are a bit more than I want to pay. Another person mentioned Sundown E series have been used 4th order. What sub would you recommend.
As I look, what specs should I be looking at that indicate that it may work in 4th order. Ive heard a coupld of times, if the sub works sealed it works in 4th order? Another forum said low Fs and high QTs?
Jroo
Jroo
richmond virginia
Slobalt
vegang
vegang
