TnT_Sounds 10+ year member
profiling gets **** done!
I got a question for you guys, what should I do when Im putting the top on? Im not going to seal around with silicone or use wood glue incase I ever need access to the subs inside the enclosure. I was thinking about putting some sort of rubber stripping such as peel and seal along the top pieces and then just screw the top down on top of that.
Any suggestions or other thoughts would be great because Im stumped and Im not sure if it would even workas far as being air tight
