4th order builder needs HELP!!
  • 4
Goldy
Hello,
I'm new here i had built a few enclosures recently and now i want to build a box specially for Bass races, my car has a resonant frequency of 47Hz and last time with a 700W amp and a Linear response drive around box I got 136dB's at 47hz. I simulated a box design in WinISD that has a Gain at 47Hz of +12db.. would this mean that in a bassrace in real life im going to get 136dB+12dB?
Can anybody help me with this because I really dont want to build the box if its going to be useless for dB races.
This was the box i simulated in WinISD + couple of extra details:
Driver : Spl dynamics xtr 300d2
Vas : 42.7
Qts : 0.45
Fs : 31.70
SPL : 86.60
Number of drivers : 1
Box type : 4th Order Bandpass
Box size : Front chamber 2,82 Ft3
Rear Chamber 1,58 Ft3
Tuning frequency : 46.50 Hz
Vent : 1 vent(s) -> Front Chamber
14,5in length for each
6,7 x 6,7 in rectangle
Box internal dimensions
W - 16,5 in
D - 16,5 in
H - 26,8 in
L1 - 17 in
L2 - 9,6 in
Can anybody help me about this problem?Would this enclosure perform well at 47Hz?
Or can you suggest any changes to it?
Thank you!
I'm not exactly the best guy to be talking to about BP's, but from what I understand you want to keep the gain ~ 3db. But that's probably a rule of thumb for a daily box. I'm not sure what you could get away with for burps.
Also, it would help if you put your specs in US units so that anybody that may want to help doesn't have to do the conversions.
Thank you //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif hope someone will help me... i never built a box like this so i have no experience i just want to do a burp... and smoke the guyz with bass-reflex boxes.. don't want to destroy the speaker... actually as i simulated in winisd im only going to get a response from 45-49Hz.. nothing more... i have no ideal what to do!
Please help me
I would recommend going to pwk designs website and purchase a box design. They are great boxes I have a few designs from him myself and I am very impressed
Yeah...talk to PWK or a guy from the DIY forum named TJ Mobile Audio (he's doing mine). Their not cheap by any means; no $20 cutsheet. But they will model your entire vehicle and geometry of association with the box, subs and power.
I understand i dont want nothing estetical or special sounding i want this enclosure only for SPL use!To give the most amount of sound at 47hz... i dont even care if i dont even hear it singing on other notes //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
937
is this a ported enclosure or a 4th order? If 4th and tuned to 33hz, unless specifically designed to do that, it wont have any bandwidth. It might...
I’m going to stick with the 4th order bandpass for now and see if it can improve it. The bandpass actually plays 100 rebased songs good.
I'd try rear facing. Have you tried opening the trunk to see if that restores your bass?
Any direction you orient a sub can affect it's output, this true even more so in a car. Nevertheless it doesn't add an order and generally...
Goldy
Goldy
Romania
Goldy
    May 12, 2024
Brendon Jenness
    May 11, 2024
