4th Order BP for 2 18"s
A correctly designed and executed bandpass will have more output than a standard ported, and better sound quality than a sealed.
You will NOT see a gain in SPLin a bandpass over a good ported box.
And are you going to assmble it with the subs already installed on that baffle? Dont see a way to remove them or anything once there installed
You sir, are and idiot.
You may have to re-do the box a couple times, but yes you will.
Skill. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
You're wrong sir. The loudest Superstreet van in DB Drag is a bandpass.
Bandpass designs are very hard to get right but once you get it, you will notice the difference.
Wait why would it be so hard? If you design it right, then you just build it... where would the error be that would make you rebuild the same box multiple times...? jw..
because sometimes things don't always work out as well in real life as they do on paper. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
terra
terra
Yes
denali804
