4k-5k @.5 ohm daily???
.5 ohm daily on the memphis?
If ya got the electrical...ive seen it done
40.1 will not let you down...believe it or not my next door neighbor has 2 at .7 strapped(.35 final) and plays music on them with only 2 nsb125s and stock alt.....only drops to 11s after a few min of songs:crazy:
These are the 2nd generation....they are bigger than the first generation...These have improved power supplies...They run cooler more efficient and are stronger amps than the first ones....Here are a couple of internal shots....
As you can see in the quality of the parts...no expense was spared in the build of these beast.....
crossfires are a good bet, those atomics are nice too
the mojo 4kw's CAN do it but not only do you need a beasty *** electrical, itll probly still run warmer than it needs to. I personally wouldnt run the mojo daily at .5ohm (.35ohm DCR) unless you can run at a MINIMUM 14v full tilt. I've heard that if you go under 1ohm you'll want do be doing 16v, under 14v they freak out if you're under rated imp.
this is coming from the guy i bought my 4kw off of who was running 8 or 10 of these iirc.
i miss my mojo 4kw //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
i miss my 18
i miss my stereo //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif:(//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
gHOstFaCe
Dade County 305
gHOstFaCe
Miami, FL
Silverbane
