4000 rms 98 Camry, Tantric Sounds, SoundQubed
audio technix 80 mill sound deadner
the fuses are in. audio technix dual 1/0 gauge terminal fus holder, rapter fuse holders, ixos fuse holder, RF fuse holder
finsihed installing the pioneer deh 80 prs. it wouldn't fi cause of all the rca and random stuff behind the headunit. so its not 100% flush, but it still looks nice.
one of my rca wasnt long enough. either gunna buy a new rca or use a connecter and another set of rcas to extend to the trunk.
That is all i have gotten done for the day. waiting on more terminals to run 2 runs of positiv and 2 runs of negative 1/0 cca.
These things banging yet ? Let's see some vids !!
not yet, still gotta run pos and grounds, build a box, then seal my trunk. doing a forward firing sealed trunk. i only have till the 13th of jan before i go back to school so hopefully will be done by then.
You should do a run direct from alt to rear batt bank ... Even if you have to only do a single pos and neg off the battery for now .. The alt to back run should help more then your second pos and neg run .. Also be sure to still do 1 or 2 dedicated rear grounds as well ..
i was wandering about this, all my batteries are agm, would my front batt still get a decent charge along with the rear? so only have one run of postive between front batt and rear bank and have one run from alt to rear bank?
Yes that's correct .. And your front batt will charge fine .. If your really worried toss another 2ft piece from alt to front batt as well .. Not gunna matter .. But yes I'd rather have a single run of each from main batt and a single run from alt to rear .. Then 2 runs each from front batt and no run from alt to back .. Now if u have enough wire to do it all then go for it .. Just remember there is no reason to have more wire then what your alt and front batt are capable of sending
thank you, i will do one run to rear bat then.
  • Locked
Up for grabs is a Gravity Warzone 4000.1 mono amp. This is a solid low budget sub amp that does a solid 1000 or so watts at 1 ohm, maybe a bit...
Have you tried connecting the amp to a car battery? No subs, just power. If it protects, amp is bad. If no protect, subs/wiring or ATX power...
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
thatguy12
thatguy12
Madtown, WI
Timmy13091
SPLBassJunkie
    May 21, 2024
    May 20, 2024
