4 vs 8 Ohm car speakers
Most likely deck gonna go boom. Even if it doesn't go boom it's gonna have problems with CDs skipping (if applicable) and such from the extra heat.
Depending on the speakers that he's putting in there, they may sound worse than stock. Some the Boston stuff is designed to run off of 35RMS and they do pretty well off of an aftermarket HU power, but most stuff will be severely underpowered and sound worse than keeping the stocks. Unless he's adding a sub, I wouldn't replace the stock speakers unless they're designed for low power applications, and even then a small amp will make a huge difference over the SQ you can get out of a HU's internal amp.
The Biden administration on Tuesday backed down on a controversial proposal to direct the IRS to collect additional data on every bank account...
31
6K
It also lowers the amps efficiency and raises the current draw.
466
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
303
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
998
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
pareif
pareif
cleveland, oh
Wattser93
    May 18, 2024
    May 16, 2024
