4 Sundown Nightshade 18s In A Yukon Xl
gtbike900
1loudyukonxl
796
ohio
So I Just Bought 4 Nightshade 18s And I Was Wondering What Would Be A Good Box Size To Use Im Thinking 19.5 Cubes With 4 6 Inch Aeros Tuned To 27 16 Cube After Displacemnt And Bracing Made From Birch With 2 Saz4500ds At .5 On 8 16vs And 4 270amp Alts
ok since this is the identical setup i was going to run in my burban i will tell you that you will want a 20 cubes box after displacement and the alts are good as far as ports go might want a little more port area and tune to 32hz the nightshades loved it..Now i have to up my build
665
10
gtbike900
1loudyukonxl
gtbike900
ohio
gtbike900
