4 subs that will equil = 1000RMS total
what 4ohm sub can i buy 4 of so i can get a total of 1000Wrms @ 2ohmz
im guessing you have a 1K@2 ohm rms amp since you came up with those figures and i dont think they make that many amps that are 1000x4 rms @ 2 ohms so im thinking you have a mono amp with 1000rms at 1 channel. So if you want 4 subs to run off that amp at 1,000 watts rms your going to need to get 4 dual voice coil subs that are 4 ohms per coil. wire each sub in series to give you 8 ohms per sub, then you would need to connect the 4 subs in parallel to give you a 2 ohm load, but remember you would be feeding 1000 rms to each sub but since each sub is in series your feeding 500 to each coil.
Get 4 dual voice coil subs with 4 ohm coils that handle 500rms per coil.
Before i can begin to recommend a sub i need to know more information...
what are your goals SQ/SPL/SQL.. how much space do you have... what size subs do you want.... how much are you looking to spend...???
Zinthesis
Zinthesis
Perth, Western Australia
Nukedsodapop
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
