4 shallows in siverado, need answer on box design.
if you can, i would go ahead and separate each chamber. If one sub happens to fail it could interfere with the others if its common chamber. For "bracing" and safety i would separate each chamber.
usually there is a small hump in the middle of the floor which makes it hard to get 4 chambers all the same size but two per chamber divided right in the middle would be ideal
2 subs or all could share but the best is to separate all of them in case o shit. and you can use thinner wood in between to keep it lighter on something that small. Hell build the whole thing in half inch why bother with 3/4 for that. of course people will yell o but use 3/4 oooooo or it will go poop. that small of panels it will be plenty stiff.
mlocke32425
mlocke32425
florida
Supergumby5000
