4 radios blow in 2 months WTH
southport2014
I have a 2002 ford explorer and I have had 4 different radios in my car in 2 months.
Radios are Kenwood x996
Cheap Kenwood 323 or something
Alpine 9883
Kenwood x697
Kenwood 996 had the engine whine after install too.
Kenwood 323 had Engine whine after unplugging the rcas on the amp
The 9883 started to smoke after a month of use
And the x697 had the engine whine after installing my amps
I do not understand it its driving me crazy. And yes I did undo my battery in my car before install on the last 3 radios and still had the same problem
Can someone please help I can not keep spending money on radios
Have you followed your constant wire to find a break in the wire or if the fuse is causing an issue?
Could even be someone bypassed the fuse and/or changed the wire going to the fuse.
Bad ground or dead short in the wiring harness under the dash would be my guess
Well mt ground is on my back seat frame I sanded it down and eveeything I imagine it would be good enough. In my old 98 explorer I always swapped amps and stuff out with out undoing the battery and never had a problem.
if you are still using the factory wires for power if there was a short the fuse would be popping. is it the factory amplified system? what kind of amp are you hooking up full range or sub or both
southport2014
southport2014
Indianapolis, IN
southport2014
michigan born
    May 14, 2026
michigan born
    May 14, 2026
