4" port
Originally posted by Grateful If i'm cutting a port for a 4" port what do most people use for material and do i cut the hole in my box that size or would it be bigger tho fit somthing in there with a 4" hole.
popularmaterials used is a PVC pipe...
there are mftrs who sell ports with flared ends to minimise air turbulence...
as for the actual cutout.. buy the port first and measure the exterior dimensions...PVC pipes aren't 1mm in thickness..
Originally posted by Grateful If either way i'm going to buy one what would be better to get.And do they make ones that are 11" long if i didn't use pvc.
hmm, I don't think so...
in that case, you're better off buying a PVC pipe and just using the flared ends that can be purchased separately~
i dont think there is any way to connect the flares to the pvc....and I have not seen 4 inche flares either....just use pvc...paint it black to match the carpet.
why would he paint it black if his carpet was not black????
If his carpet was gray then he would paint it gray...you told him to paint it black...~misinformationgiver~ :p :p
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
699
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
871
845
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
Grateful
Grateful
Rutland,VT
evo2k3
    May 18, 2024
    May 16, 2024
