4" Flared Ported Enclosure
dgibb79
I recently bought one rockford 15" T2d4 sub and rockfords10001bd one-channel amp. I customize the box using two 4" flared ports instead of straight ported to have some space. The two ports are tuned at 37hz. I'm big on the rap & r&b so is this a good set-up for this sub to get good lows and spl anyone? Here are my calcs. for the the enclosure.
net internal vol. = 3.25 cu.ft.
port vol. = 0.19 cu.ft.
sub. displacement = 0.176 cu.ft.
total internal vol. = 3.62 cu.ft.
box dimensions = 26"(w) x 18"(d) x 17"(h)
trunk dimensions = 35"(w) x 43"(d) x 17"(h)
Thanks,
dgibb79
IMHO, you should tune lower than 37hz.
Being big on rap, there are notes that go lower than 37hz.
Especially having a 15" woofer (easier to hit low notes), don't waste your time tuning higher for spl.
That will really bring your setup to life.
i have four 4 inch external ports for my 15. i dont think 2 would be enough. my box is 4.0 cube tuned to mid 30's.
are they flared?
my box was 3.5cu' tuned to 32hz with 2 4" precision ports. with 1200w i did a 146+db on the TL. now i have the same volume with 60sq" of port, same tuning, and can't get past 142db. over all the box with the 2 4's sounded better also. that's all i'm going on.
are they flared?
Can't go on anything better than 1st hand experience.
i have one that is built to adire's spec that sounds better then my current one and has more spl. i think it has like 28sq" or so. i'm just too lazy to swap them. the one with the 2 4" ports i sold for $50.
Are flared ports betteR?
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
I scrolled thru there trying to find TS specs and must have missed them or they weren't displaying. Anyway, looks like 2cuft tuned to ~35hz was a...
I want to try my hand at a ported box for one IDQ12. I built a sealed box a few years ago and it sounds good but I want to see how ported...
dgibb79
dgibb79
Birmingham, AL
Trixter
    May 20, 2024
    May 20, 2024
