4" Flared Ported Enclosure
dgibb79
I recently bought one rockford 15" T2d4 sub and rockfords10001bd one-channel amp. I customize the box using two 4" flared ports instead of straight ported to have some space. The two ports are tuned at 37hz. I'm big on the rap & r&b so is this a good set-up for this sub to get good lows and spl anyone? Here are my calcs. for the the enclosure.
net internal vol. = 3.25 cu.ft.
port vol. = 0.19 cu.ft.
sub. displacement = 0.176 cu.ft.
total internal vol. = 3.62 cu.ft.
box dimensions = 26"(w) x 18"(d) x 17"(h)
trunk dimensions = 35"(w) x 43"(d) x 17"(h)
Thanks,
dgibb79
IMHO, you should tune lower than 37hz.
Being big on rap, there are notes that go lower than 37hz.
Especially having a 15" woofer (easier to hit low notes), don't waste your time tuning higher for spl.
That will really bring your setup to life.
i have four 4 inch external ports for my 15. i dont think 2 would be enough. my box is 4.0 cube tuned to mid 30's.
are they flared?
my box was 3.5cu' tuned to 32hz with 2 4" precision ports. with 1200w i did a 146+db on the TL. now i have the same volume with 60sq" of port, same tuning, and can't get past 142db. over all the box with the 2 4's sounded better also. that's all i'm going on.
are they flared?
Can't go on anything better than 1st hand experience.
i have one that is built to adire's spec that sounds better then my current one and has more spl. i think it has like 28sq" or so. i'm just too lazy to swap them. the one with the 2 4" ports i sold for $50.
dgibb79
dgibb79
Birmingham, AL
Trixter
