4-ohm or 2-ohm
well if your just gonna have one sub then get the 2ohm 1000rms@ 2ohm
?????????????? //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif :crazy: //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Those subs are dual voice coils, so if you want 1 sub to get a 2ohm load on the amp than u need to get the D4 (Dual 4 Ohm) version. Or the ts-w3004spl model, if you get the ts-w3002spl you can only wire it at 1 or 4 ohms.
There are many guides that can show you how to wire your subs, rockford fostgate has a good one
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
Sounddomain has one too
http://www.cardomain.com/shop/wooferwizard.pl?num_of_subs=1&impedance_of_subs=dual%204%20ohms
If you want 2 subs, get the dual 2ohm, if you just want 1 sub, get the dual 4.
Like mentioned above, those link will direct you to wiring diagrams that will show you which configuration is best for you.
solidcrowd
solidcrowd
Buffalo, New York
Ali1
vegang
vegang
