4 gauge power, 8 gauge ground
i thought i read somewhere that u can only use a larger ground than power not the other way around...could be wrong though
Just common practice. As others have said, as long as the amperage demand isn't that great, 8g can work, and the shorter the wire the better it'll work. But for how cheap you can get 4g wire, you're just better off going 4g.
If you start having any issues with static, fading, voltage dropping, excessive over heating of amp, or amp shutting off, consider the 8g ground as the reason first.
mathxew
mathxew
Los Altos, CA
n2audio
